Help Partical Filter.
CHRI55
Yes its been Tango'd
Oct 15, 2006
255
Norfolk
Hi guys so i've just had the turbo replaced on my car recently but it seems there is also a problem with the particle filter as well.
Car is 2010 seat leon CR fr TDI 170 with about 120,000 miles.
VCDS fault code bellow:
1 Fault Found:
009315 - Diesel Particle Filter
P2463 - 000 - Excessive Soot Accumulation - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Mileage: 193025 km
Time Indication: 0
Date: 2127.14.31
Time: 19:13:42
Freeze Frame:
RPM: 782 /min
Speed: 0.0 km/h
Pressure: 46 mbar
Hex Value: 0xFF01
Temperature: 138.0°C
(no units): 25.5
Mileage: 1660 km
Readiness: 1 1 0 0 1
Is there away to get past this problem or some sort of sensor that could of gone. But obviously it wont regen to clear as stuck in LIMP MODE.
Thank you.
R3k1355
1,787
251
Yorkshire
VCDS can force a regen, although if it's too soot packed it's dangerous to force a regen it can catch fire.
You could try one of the DPF cleaner sprays, clean out the accumulated ash and soot.
Might need a code reader or VCDS to turn off the engine management light after though.
Apr 1, 2023
15
As R3k says, could force a regen, other than that you could possibly try a DPF cleaner such as REDEX or something similar, failing that Darkside does a nice DPF delete kit it would also mean that you'd have to get it remapped though.
All depends on how deep your wallet is really a delete kit and remap soon adds up.....
