Got my OBD dongle, Carista app, all worked very nicely.
Had a go with Torque and that seemed fine too.
Also good news no error codes present after a full scan using both apps.
It mentioned a few things it couldnt connect with, like back doors, but no problems reported.
Got needle sweep enabled and a few other bits amd bobs.
For some reason I thought you could disable the cornering lights but I cant see it in the list.
Here's my options
The following settings were available specifically to your vehicle using Carista:
Doors / Windows / Remote:
Auto-lock doors when moving
***** *YES* / NO
Auto-unlock doors when key is taken out of ignition
***** *YES* / NO
Auto-lock trunk when moving
***** *YES* / NO
Unlock trunk when doors are unlocked
***** *YES* / NO
Blink turn signals when locking/unlocking with remote
***** *YES* / NO
Allow configuring beep when locking/unlocking
***** *YES* / NO
Beep when locking with remote
***** *YES* / NO
Beep when unlocking with remote
***** *YES* / NO
Unlock doors via remote
***** DRIVER'S DOOR ON*1ST PRESS, ALL ON 2ND*/ *ALL DOORS ON 1ST PRESS*
Enable settings for opening/closing windows and sunroof
***** *YES* / NO
Open/close windows and sunroof via long-press on remote
***** *YES* / NO
Open only driver's window via long-press on remote
***** YES / *NO*
Open sunroof via long-press on remote
***** YES / *NO*
Close sunroof via long-press on remote
***** *YES* / NO
Sunroof action when opening via remote
***** SLIDE / *TILT*
Open/close windows and sunroof by holding key in door lock
***** *YES* / NO
Blink turn signals when done closing windows via remote
***** *YES* / NO
Enable remote control buttons when ignition is on
***** YES / *NO*
Instruments / Display / Dings:
Instrument cluster region (affects ext. lights too)
***** GERMANY / EUROPE/OTHER / USA / CANADA / *GREAT BRITAIN* / JAPAN / SAUDI ARABIA / AUSTRALIA
Gauge needle sweep at startup (req. instrument cluster support)
***** *YES* / NO / NOT AVAILABLE
Seat belt warning
***** *ENABLED* / DISABLED
Lane-change turn signal auto-flasher
Lane-change turn signal auto-flasher count
***** 1 FLASH / 2 FLASHES / *3 FLASHES* / 4 FLASHES / 5 FLASHES
Lights:
Allow configuring daytime running lights via dash display
***** YES / *NO*
Use designated DRL bulbs as daytime running lights
***** YES / *NO*
Use low beams as daytime running lights
***** YES / *NO*
Use fog lights as daytime running lights
***** YES / *NO*
Turn off daytime running lights ("wink") when turn signal is on
***** YES / *NO*
Turn off daytime running lights when parking brake is on
***** YES / *NO*
Coming-home lights
***** ENABLED / *DISABLED*
Leaving-home lights (req. auto headlights)
Coming-home lights mode
***** *MANUAL: FLASH HIGH BEAMS TO ACTIVATE* / AUTOMATIC: WHEN IT'S DARK (REQ. AUTO HEADLIGHTS)
Coming/leaving-home lights use…
***** *LOW BEAMS* / FOG LIGHTS
Coming-home lights duration
***** 5 SECONDS / *10 SECONDS* / 15 SECONDS / 20 SECONDS / 30 SECONDS / 40 SECONDS / 50 SECONDS / 60 SECONDS
Leaving-home lights duration
Turn off all lights when headlights are left on and ignition is switched off
***** YES / *NO*
Turn off front fog lights when high beams are on
***** YES / *NO*
Turn off rear fog lights when high beams are on
***** YES / *NO*
Flash brake lights in emergency stopping
***** YES / *NO*
Flash hazard lights in emergency stopping
***** *YES* / NO
Brake lights work even when ignition is off
***** YES / *NO*
Other:
Lower passenger-side mirror when in reverse gear (may need memory seats)
***** YES / *NO*
Auto-enable rear wiper when front wipers on and reverse gear engaged
***** *YES* / NO
Auto-enable rear wiper when front wipers on (interval) and reverse gear engaged
***** *YES* / NO
Auto-enable rear wiper when front wipers on (continuous) and reverse gear engaged
***** *YES* / NO
Additional 'tear' wipe after rear window washer use
***** *YES* / NO
Obtained with Carista 2.2.1 for Android.
Download app:*
https://play.google.com/store/apps/details?id=com.prizmos.carista
Facebook:*
https://www.facebook.com/caristaapp
Sent from Samsung Mobile on O2
