just run it on HI with the air con running for a few hours, it should pull all of the moisture from the car.
I hope im not intruding here (id rather ask here than open a new thread) but I have a similar problem but the wet patch is only on the nearside rear footwell in the center.
I cant see how a leaky door would cause dampness hear but no-where else...
any ideas?
Ol'Timer - Do you mean pouring water onto the rear passenger door window to see if water is getting in at the bottom of the glass there - and then seeping down inside the door?
And sorry to keep going over old ground - but how likely is it to be the Pollen Filter, given that the front footwells are dry? - it's only the back ones that are wet....
