possible best mod eveeeer
LeonCR
2,389
it wont open on its own after being left for any length of time
Yes we had the poppers from vw and 550 nm struts
Jarre
5,365
11
Stockton-On-Tees
I didn't have that issue with mine. My struts were from SGS Engineering though so slightly different. Only other thing would be that my poppers were out further than yours giving it that extra push.
Jimbobcook
6,150
2,533
That would be mildly annoying, the only thing I didn't really like is that when it reaches the top if feels like it's ripping the boot off the car lol
LeonCR
2,389
had the popper set it various positions so prob related to your struts then
TimSawf
865
South Manchester
About 12 months after fitting the stronger struts, my car developed a rattle at the back. It was tracked down to the struts. The mounts were fine, we could only think that the sharp jolt when it opened fully had, over time, damaged the pistons. With the standard struts on, it comes to a very gentle stop when opening.
Daniel M
Blackbelts & Chickenheads
Apr 18, 2013
2,874
7
Middlesbrough
Is yours a pre FL or FL? I didnt think the standard struts were strong enough to open the tailgate?
TimSawf
865
South Manchester
Mine's a FL and it won't open the tailgate now with the standard struts. Like most, it didn't work all the time anyway. It still has the Scirocco bumpers on so it clears the lock when popped, still better than when it left the factory.
t121anf
Newbie
May 14, 2004
570
9
Fitted my VW Bumpers/Poppers/Buffers and it worked great in the garage, but hasn't work again since.
I'll try to adjust the bumper but I think it's a failed mod at the moment. :-(
I'm happy with the new stronger struts though as last winter my SEAT ones struggled in the cold weather to open the boot properly, banged my head a couple of times.
Jimbobcook
6,150
2,533
That's a shame :( I will wait for my poppers to arrive and see what happens lol but like you I'm happy with the new struts as mine stopped half way hot or cold weather lol
Jarre
5,365
11
Stockton-On-Tees
Have you adjusted the length of the stoppers? And also ensured that the spring is active? As you can 'twist' it just so they're standard stoppers.
t121anf
Newbie
May 14, 2004
570
9
Spring is working, I followed the youtube vid for a golf which said to push them in fully, I'll adjust them out a little.
It pops open further than it used to, just not enough, it's odd as it was fine last night in the garage. On the drive I thought it might be the angle (nose down, more weight to push up) but the works car park is quite level.
lc_allan
Northern Monkey
Sep 15, 2006
3,389
Mine are like most but I've only had them fitted while the weather is cooler. I suspect the heat may help the struts work a little better on the first opening. If I leave it overnight or a few hours the boot only pops open a little. Enough to get fingers under which saves me touching the badge any way. (Wrapped)
Any subsequent openings work ok until it's left for a good few hours.
