Problems with my Seat Leon Cupra R 1M
Apr 30, 2022
7
Hello guys, i've Vagcom'd my Car and got some errors from it. Also since i changed my Ignition Coil Modules and Spark Plugs to new ones my car started to smoke like crazy, the smoke coming out of it is bright white and it smells like normal gasoline, at first i thought it was my turbo but since it smells like normal gasoline i think it can't be the turbo. I'll drop bellow my fault codes, i would be really happy if i could get some help.
Address 01: Engine Labels: 06A-906-032-BAM.lbl
Part No: 1ML 906 032 A
Component: 1.8l R4/5VT 0002
Coding: 10510
Shop #: WSC 00000
VCID: 3F8DF6FB3D7DB57178-515A
VSSZZZ1MZ5R045825 SEZ7Z0D2697953
5 Faults Found:
17863 - Exhaust Gas Temp Sensor 1 (G235)
P1455 - 35-10 - Implausible Signal - Intermittent
17524 - Oxygen (Lambda) Sensor Heating; B1 S1
P1116 - 35-10 - Open Circuit - Intermittent
17511 - Oxygen (Lambda) Sensor Heating; B1 S1
P1103 - 35-10 - Performance too Low - Intermittent
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
P1297 - 35-10 - - Intermittent
18010 - Power Supply Terminal 30
P1602 - 35-10 - Voltage too Low - Intermittent
Readiness: 0110 0101
  • Log-VSSZZZ1MZ5R045825-222720km-138391mi.txt
Alexis27
2,100
453
Manchester
The circuit board in the sensor can fail, causing terrible mpg. Second hand replacement the best way since they're horrendously expensive new.
Probably not connected to your big issue though.
Reactions: Almeiidaa
Apr 30, 2022
7
thank u very much for your reply.
mty12345
3,771
476
bristol
I'm confused by the smoke part tbh, white smoke on a petrol/gasoline engine is usually steam caused by coolant getting burnt, but in this case I doubt it. If the smoke smells of petroland it only started after changing the plugs, it sounds like it could be unburnt fuel. I would remove the plugs and check that the electrodes and the gaps are ok.
When it comes to the sensors, I would check fuses and wiring, then maybe take Thai up on his offer of some 2nd hand parts. New EGTs are expensive
http://wiki.ross-tech.com/wiki/index.php/17863/P1455 <<< ross tech website is the best place to check any fault codes.
You can ignore/delete some codes for now:
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!) This code can be set in cold weather on cars that have been remapped, it's a coding error and you can ignore it 99% of the time.
18010 - Power Supply Terminal 30 This code just means that the battery went flat or that you disconnected it.
