Rear Wash - where does the piping go?
Tildmeister
Hello all,
Pretty sure I've got the standard rear wash problem (pipe becoming disconnected etc.), however I'm not completly sure I know where the pipe runs from the bottle to the back. Seem to have water coming out of the plastic here - but still not entirely sure. Does it run under the passenger side sills or not? Many thanks in advance for any help.
Tilds
dg-1984
254
Glasgow'ish
The rear plasics on the passenger side can be removed and you can get to one connection, that is famous for coming loose.
Tildmeister
That'll be it then - fantastic. I heard a rumour that the pipe ran through the roof lining (over the passenger side). Cheers.
alexj124
294
Edinburgh
where is it actually leaking?? Normal places are in the boot itself and also if you squirt the rear washer if it leaks from the rear whell arch there is a connection just above the seat belt
Tildmeister
Sorry - just realised I wasnt entirely clear... It appears to be leaking from under the plastic trim on the passenger side sill.
