According to Elsawin, no, but it does look like there's special tools to aid in doing the job.
can't show images, but this is a copy & paste
Removing and installing sump
t Removing → Anchor
t Installing → Anchor
Special tools and workshop equipment required
t Socket “T”Spanner -U-30013-
t Wrench -U-40051A-
t Manual drill with plastic brush fitting
t Protective glasses
t Silicon sealant → ETKA (electronic parts catalogue)
Removing
– Remove the central soundproofing pan: → Rep. Gr.50
– Disconnect 3 pin electrical connection on oil level and temperature sender -G266-.
– Drain engine oil.
NoteObserve disposal regulations!
– Unscrew the bracket -arrows- for the supercharger air tube, on the oil sump attachment.
NoteLoosen the oil sump bolts on the flywheel side of the engine with the articulated wrench -U-30013- and unscrew them with the spanner -U-40051A-.
– Remove the 3 bolts attaching the gear bell to the sump.
– Unbolt the oil sump.
– Remove oil sump. It may be necessary to release sump by tapping lightly with a rubber head hammer.
– Remove sealant residue on cylinder block with a flat scraper.
WARNING
Wear protective glasses.
– Remove the sealant residues at the oil sump using a rotating brush, e.g. a hand drill machine with plastic brush (wear protective goggles).
– Clean sealing surface; must be free of oil and grease.
Installing
Notet Replace gaskets and seals.
t Observe use-by date of sealant.
t The oil sump must be installed within 5 minutes after applying the silicone sealant.
– Cut off tube nozzle at upper marking (nozzle approx. 3 mm).
– Apply silicone sealing compound -D 176 404 A2- → ETKA (electronic parts catalogue), as shown, to clean sump sealing surface.
Notet The length should have a thickness of 2...3 mm.
t Pass next to the bolt holes, through the inner side -arrows-.
t The sealing compound bead must not be thicker, otherwise excessive sealing compound could enter the sump and block the oil suction pipe strainer.
– Apply the silicon sealant to the clean sealing surface on the conduction frame -arrows-.
– Install oil sump immediately and tighten bolts in the indicated sequence:
– Pre-tighten the bolts -1 … 20- diagonally to 5 Nm.
– Tighten sump/gearbox bolts -arrows- to 45 Nm.
– Tighten the bolts -1 … 20- diagonally to 15 Nm.
Notet When fitting the oil sump to the removed engine, take care that the oil sump is flush with the engine block in the area of the engine flywheel.
t After fitting the sump let the sealer dry for 30 minutes and then fill with oil.
– When fitting the air conduits with the insertion joint, ensure that the attachment clip -arrow- clips audibly into the attachment protrusion -A-.
Installation is carried out in the reverse order to removal, observing the following:
– Top up with engine oil and check level → Fig.
