Retard Problem on motor loading
cihansenguler
Hello guys,
There is an stupid retard problem in my 2009 Cupra. Btw i use 95 oktan + %20 toluen wth superchips stage 1 ECU. As you can see below videos there is retard issue for all cylinders while the car is trying to first moving or first motor loadings on speed up.
Also i realized that this retard values are increasing in heavy traffic depending on engine temperature.
What do you think about this issue? Is there anyone who has same problem?
https://youtu.be/l4XgLP-7ek4
https://youtu.be/7nNoyV_1NUs
cihansenguler
I have seen balancers that were seperated on the inside and outside areas to cause the timing to show as incorrect. Not that this is what you may be expierencing though.
Hello Lillian,
Which balancers do you mention? My problem can be balancers problem because there is a sharky movement while first moving.
LG-D802 cihazımdan Tapatalk kullanılarak gönderildi
