Reverse Cam 12V
Jan 16, 2022
Hi all,
I have given myself a project of installing a reversing cam on my Ibiza 2016 (3 door) but I am running into an issue. When I put the car into reverse with the electrics on it works fine and the feed shows up. However, if I turn the engine on, the feed stops working. I've read somewhere that this is due to the voltage dropping to 9V when the engine is running (CAN BUS?) and if I install a relay it will stop this problem. The tutorials that I've found to install the relay say that I need a constant 12V+, however I cant seem to find one in my boot? I don't have a cigerette lighter in my boot.
Any help would be greatly appriciated!
Aidan
