cool, I hope you have the right tools to get the oem silicone turbo pipe off as otherwise its gonna be a pigggg
Eeeerrmmmm...... Fancy donating em for the day? Hahaha
What's needed?
What's needed?
you need a special pair of grips to get the spring clip off, you can't do it with standard tools!
Replacement not a problem as you can use jubilee clips and point the connector easily to tighten / remove.
If you have any mechanic mates borrow one rather than buy
I quite liked the induction whistle I used to have. You need an exhaust next lad, to give the bass to match the treble
http://www.youtube.com/watch?v=1dMYwIO_4Z0
http://www.youtube.com/watch?v=aGbiPeQ6k7k
Once your ecu adapts to the extra air it it hopefully stop doing the whole nearly stalling thing.
So far my list of problems:
Rattling - cant pinpoint exactly where its coming from, but it sounds like from behind the dash/lower part of centre console/under handbrake. Open the door and it sounds like its coming from the centre part of the exhaust. Problem is, its only there once warmed up, and its not there every day. Its also only rattling when at idle.
Head tecchie came and looked at it the other day, so hopefully he'll know what the problem is (every other time its been put it in the garage, they can never replicate the sound. So when it happened again, I happened to be round the corner from service dept, so I made them come and listen lol)
Starting to have trouble getting into 1st gear - Only noticed in the last few days. If i'm sitting at lights, I sometimes have real trouble getting into 1st. Normally this can be cured by releasing the clutch then re-applying. But that doesn't always work
I think I have solved this now I have the Neuspeed fitted. It is still very marginally there, but it seems to have vanishedSlight hesitiation/flat spot at around 3-4.5k revs Only noticed the flat spot the other day. It has the feeling of a 'double boost' ie I feel the turbo coming on boost, then it gets to around 5k and i feel it come on boost again lol It never used to do this. Looking back at some very old threads, i've noticed 1 or 2 people saying the 'Cam Variator' can be the cause of such an issue. So I want to take it in and see what they think. This 'cam variator' is apparantly also possibly the reason why these engines sound like diesels on tickover??
Also while its in I want them to check the cam follower on the fuel pump. Am still a little unsure if my engine is actually affected or not But regardless I want it checked to be 100% sure.
See next quoteOnce your ecu adapts to the extra air it it hopefully stop doing the whole nearly stalling thing.
Wierdly i'm still getting this. If I brake quite sharply from a relatively high speed (70mph) and dip the clutch early. The revs will drop to as little as 500rpm, then it kinda works out its gonna stall and increases till idle. Earlier on, I was out of gear rolling down a steep hill (blackheath hill actually, jason will know where i'm talking about lol) and it was proper 'hunting' for the idle????
Not sure if the ecu is still adapting but its had a good 500miles to get used to it so far. Am leaving this for a few more miles before I make the descision to take her to stealers. But that means I have to put it all back to standard etc etc and I really really just cant be arsed!! It does need to go in soon as there are a few things to be sorted. I've posted these thing in an earlier page. So we'll see how I get on lol
When are you next around, I will take some logs of your car.
Actually i'm free during day on friday 25th? or that weekend?
