Stabiliser bushing size.
Nov 13, 2023
11
Hi all!
I would like to ask you if the stabiliser on the front axle are the same size all along? I measured 25mm with the plastics on, near the tire.
But if I look everywhere on the websites, it says 24mm.. I would like to replace all my bushings with strongflex.
Thank you! :)
serdar_18fr
329
Hi all!
Thank you! :)
There are three sizes available from the factory: 23.2, 24 and 25mm.
It depends on the chassis type and probably engine type too.
If you have the full list of PR codes for your car, it is easy to determine:
0AD is 23.2, 0AE is 24 and 0AF is 25.
Mine is an FR/1.4/125 and it has 0AE/24 mm stabiliser.
All FRs most likely have 24mm one but I wouldn't be surprised if they put a 25 on 1.8/180.
If you'd like to know for sure, I can look it up if you don't mind sending me your VIN over PM.
