Hi guys.
Engine has had some major work done recently. So posting some logs to make sure everything is working properly. I have also fitted a Badger 5 3" TIP, Jetex cone and a shiney new MAF.
Can anyone see any problems?
Cheers,
Matt
Code:
Group A: '003 Group B: '020 Group C: Not Running
RPM Mass Flow Load Ign. Timing Idle Stabilization Idle Stabilization Idle Stabilization Idle Stabilization
TIME TIME TIME
Marker STAMP /min g/s % °BTDC STAMP CF CF CF CF STAMP
2.22 2120 55.86 100 12.8 1.73 0 0 0 3
3.14 2400 82.39 100 3.8 2.62 3 3 0 3
4.03 2680 93.33 100 0 3.63 3 3 0 2.3
4.85 2960 105.69 100 3.8 4.43 2.3 3 0 2.3
5.73 3320 120.42 99.6 4.5 5.34 2.3 2.3 0 5.3
6.54 3600 134.17 100 3.8 6.14 1.5 2.3 0 5.3
7.45 3960 149.83 100 7.5 6.96 1.5 1.5 0 4.5
8.25 4240 180.89 100 6 7.85 1.5 1.5 0 4.5
9.07 4560 181.25 100 11.3 8.65 0.8 4.5 0 4.5
9.97 4920 193.64 100 8.3 9.56 0.8 4.5 0 3.8
10.97 5240 207.92 100 9 10.48 0 3.8 0 3.8
11.77 5480 214.67 100 9.8 11.37 0 3.8 0 3
12.68 5760 213.28 100 6.8 12.19 0 3.8 0 3
13.6 5960 219.83 100 9.8 13.08 0 3 0 2.3
14.4 6160 220.5 100 9 14 0 3 0 2.3
Code:
Group A: '115 Group B: '031 Group C: Not Running
RPM Load Absolute Pres. Absolute Pres. Lambda Factor Lambda Factor Bin. Bits Bin. Bits
TIME TIME TIME
Marker STAMP /min % mbar mbar STAMP STAMP
1.68 2160 114.3 1920 1400 1.26 0.883 1
2.48 2360 152.6 2070 1850 2.06 0.953 0.953
3.39 2680 185 2170 2160 2.88 0.953 0.945
4.28 3000 178.2 2170 2080 3.88 0.961 0.945
5.1 3320 189.5 2220 2170 4.68 0.938 0.945
5.99 3680 191.7 2300 2300 5.5 0.922 0.93
6.81 4000 191.7 2340 2350 6.39 0.899 0.883
7.61 4320 191.7 2340 2390 7.21 0.86 0.86
8.41 4600 191.7 2320 2360 8.01 0.852 0.86
9.23 4880 191.7 2300 2330 8.81 0.852 0.86
10.03 5160 191.7 2280 2280 9.63 0.852 0.86
10.83 5440 191.7 2270 2280 10.42 0.852 0.86
11.74 5680 191.7 2250 2270 11.34 0.86 0.86
12.54 5880 191.7 2240 2240 12.14 0.875 0.86
13.45 5960 187.2 1000 2270 12.94 0.805 0.813
14.34 5000 191.7 2300 2320 13.94 0.75 0.766
15.16 5160 187.2 1810 2310 14.74 0.766 0.665
Code:
Group A: '118 Group B: '032 Group C: Not Running
RPM Temperature Load Absolute Pres. Lambda Lambda Bin. Bits Bin. Bits
TIME TIME TIME
Marker STAMP /min °C % mbar STAMP % % STAMP
0.5 1920 30 100 1170 0.01 0.8 10.2
1.3 2080 30 100 1420 0.9 0.8 10.2
2.11 2280 29 99.6 1760 1.69 0.8 10.2
3.01 2600 29 71.8 2270 2.61 0.8 10.2
3.81 2880 27 70.6 2200 3.41 0.8 10.2
4.72 3200 27 71.8 2210 4.22 0.8 10.2
5.73 3560 27 74.1 2260 5.23 0.8 9.4
6.64 3960 28 73.3 2340 6.13 0.8 9.4
7.44 4240 29 71.4 2370 7.04 0.8 9.4
8.24 4560 30 72.2 2330 7.84 0.8 9.4
9.05 4840 31 72.9 2300 8.64 0.8 9.4
9.95 5160 32 71.4 2300 9.55 0.8 9.4
10.96 5480 33 72.2 2300 10.46 0.8 9.4
11.87 5720 35 71.8 2270 11.36 0.8 9.4
12.67 5880 36 0 2300 12.27 0.8 9.4
13.56 4840 36 72.9 2370 13.16 0.8 10.2
14.38 5000 37 76.1 2340 13.98 0.8 9.4
15.18 5160 38 0 2380 14.78 0.8 9.4
Cheers,
Matt
