Strange Rattle
TDIPower140
Just wondering if anyone else has had this same problem. Car is make a strange rattling noise at low speeds especially at low speeds and going over damn speed bumps, sounds like a can being dragged underneath the car, checked to see if there was something stuck under car but clear as a bell. Looked round the wheels and noiced a lot of grease around the front right rim could be a drive bot off but dont think it would make this rattle. Any suggestions welcome.
Feb 12, 2006
625
North Lincolnshire.
Its the rubber surround round the cv joint which is the bearing assembly fixed to the drive shaft.Sometimes they come adrift or unclipped at one end spitting the grease out.Sounds like its where your grease is coming from.
625
North Lincolnshire.
They're easy enough to repair.Just needs a tie wrap round it or a proper clip and not forgetting to replace grease in the joint.Car will also make a strange rattle in that area but usually only when you are turning,not over speed bumps.
