Bridgestone Potenzas are the worst tyres iv had on any o f my cars. For the price you'd expect them to be pretty decent.
Well...time has come, can you believe it....need 2 new fronts again!!!!
Bit annoyed as it's the outer edges on both front tyres that have gone, no tread left at all.
I had the tyres pumped to recommended PSI and checked regularly as I'd usually attribute this to under inflated tyres right?
The middle of the Tyres have plenty of tread left Should I just inflate them a few more PSI and see if the wear slows down or would the rozzers not be too happy if we got stopped with the wear on the tyres?
Maybe the softer tyre wall allows for more wear on the edges?
So that's basically 8 months...
Get your tracking check. Ware on outer or inner is usually down to alignment. If both inner and outer worn together then tyre pressures are too low ware in center pressure too high. Or could just be your driving style so slow down in the bends lol
My jetta I used to put 38psi all round because that used to take both edges off if any lower. Bit harsh on the ride but did the trick. How often do u check the pressure and do they lose much in between checks ? Slow punctures or air loss from rim will soon rip the tread off. Hope iv helped
My Khumo's are now about 50% worn I'd guess 'by eye' I bought them in early August! I've done over 4k miles in that time though, 8k miles on tyres is pretty good for me.
