Vinylling guide..
Brummy
Nazi Moderator-Bot
Mar 6, 2005
4,275
Moved to the DarkSide
Just a quick/rough guide for anyone thinking of giving it a go..
had a Bare metal Mk2 Ibiza bonnet so decided to cover it in the same vinyl thats on my roof..
Best tips i can give... PATIENCE and LOTS of SOAPY WATER.
Tools used, scissors knife silicon blade, old credit type plastic card and as you see in pic(s) hair dryer. and of course, as above... plenty of soapy water.
abhardwaj1990
Yes, I'm licking my hand
Mar 16, 2009
3,434
Shottingham
Good guide sir!
I tend to use less soapy water so it sticks quicker, and use my hands as a squeegee! Plastic, or even hard rubber squeegees tend to put hair line scratched in the vinyl for me
Thafx
Didnt really explain each stage but pictures pretty much do the talking! :)
Feb 26, 2009
5,275
Wolverhampton
When I did the b pillar trim on my car, the first one I used soapy water and I had a nightmare time getting it to lay straight and flat. Fortunately it dried ok, but the other three I did without water and had a much easier time of it.
I don't know whether it's different for wrapping a horizontal piece or a vertical piece though, I can imagine not having to fight gravity will make things easier.
TubbyTwo
Taking a break from JDM..
Jan 27, 2010
957
Ipswich, Suffolk
Used to do this a job years ago.
for curved surfaces a hairdryer is handy as it allows you to gently heat and stretch the vinyl to fit, use lots of soapy water and get a decent felt burnisher few quid off ebay, makes it a doddle to get air bubbles out and get good finish.
Also alot if it depends on the quality of the vinyl being used. I used to work with aircraft grade which was robust so it could be pulled, stretched and heated without any real issues.
abhardwaj1990
Mar 16, 2009
3,434
Shottingham
Smaller areas like B pillars would be easier with less water, you're right. But on larger surfaces like roofs/bonnets, soapy water does make it easier
abhardwaj1990
Mar 16, 2009
3,434
Shottingham
Another attempt by me for a customer
Hope Mr Brum doesn't mind me putting up my efforts :d
Before:
Bonnet off:
Cut vinyl to size, then sprayed lots of soapy water, and peeled off the backing paper:
Then used my hand as a squeegee to get the large bubbles/creases out:
Then the hairdryer, would use my heatgun but I can't find it lol
Finished:
I know I know, it's an MG haha
