Trimmer said:I would replace the tyre.. i spent £150 on a new hub and bearing extra and ended up bein the tyre. lumpy tyres do cause a droning noise simular to when your bearings are gone.
CupraTgirl said:Hiya everyone
I dont know if anyone remembers me writing a post about what i thought was my wheel bearing going? Well i think someone posted back saying that this droaning noise i hear when i drive could be my tyre rubbing?
Well its still doing it but its louder and more constant. I have listened to see if it does it when i turn corners and it doesnt do it (so in doing that i think that writes out the front wheel bearings)
I thought that it was coming from the rear when i first heard the noise (which was after i took off my Rear Wheel Spacers) and have had someone confirm that its the rear offside (drivers side) that the noise is coming from
I had to replace three of the tyres a while back so only one of them is the original Pirelli P-Zeros that the car came to me with
The one tyre that wasnt replaced is the one on the rear drivers side...it has uneven wear on it and is almost bald...could this be the cause of the noise or could it still be a wheel bearing?
Please can someone help me...responses saying 'turn your music up' will not be appreciated as that is what i was told to to last time i posted (all one for a joke but this is really worrying me)
Thank you all
Ruddmeister said:m0rk is spot on, I had this too
My dodgy rear dampers pounded my tyre out of shape, squeaked on speed bumps and I had a droning noise and vibration. At first I suspected buckled alloy wheels, balancing not being done right etc....all checked out and eventually traced to the dampers.
New dampers and new tyres needed (this was a Leon but same principle)
All after 30k miles from new
leaky damper
Pounded out of shape tyre with flat spots
CupraPower said:If it turns out to be a front wheel bearing. Just to let you know i have a spare one. (Brand new) Let me know on msn if you need it.
Ian
flashbsd said:yeah but the noise is definatley from the front, the squeak is from the rear though. no vibrations at rear or poor damping
Ruddmeister said:With mine the noise couldn't really be traced, it was also more with some road surfaces and less with others, different speeds and I could hear it more / less too.......I thought the problem was at the front too so be warned
Then agaon my Toyo T1-S tyres made much more noise than my Goodyears ...........bl000dy cars
CupraTgirl said:Yeah thats what mine has been like
Hard to tell where it was coming from, some roads more than others (motorways it is noisier) and coming in intermittently at different speeds
flashbsd said:scotty told you about the lip on the discs ABS will only make a noise if it kicks in, you weren't braking or even hard enough for ABS when we heard the sound so it surely cant be that?
So the front bearings have been inspected or are they just assuming its not that?
Hope it works out for you though, can't go having you unhappy
