Window trim removal
Senri
Hello,
Does anyone know if its possible to remove the trim from the back door?
It's not the trim arround the door, but the trim outside the door which protect the backwindow.
Speed-FReek
1,108
17
South Oxfordshire, UK
Which part do you mean? Is it part #2 in the diagram below?
zak
186
london
Hello,
If its the rubber part between the window and the door. if you open the door you can pull the rubber part out of the holes its in. there's no screws no bolts or clips even. just pull it and apply a lot of pressure when fitting it back in.
