The_one
508
England
Picked up my new MAF this morning from the stealers.
Am i ok to just fit it or do i need to disconnect battery to reset ecu etc before i fit it and go for a blast :D
Cheers Martyn, just been and done that and surprisingly the radio didn't require a code?
Oh well not gonna complain ;)
Will take it out for a drive after
Procedure for performing a Throttle Body Alignment on DBW Cars using KWP-1281:
(Check to see if the engine speaks KWP-1281 by looking in the top left of the Open Controller Screen Some examples of KWP-1281 engine controllers are 2000+ Golf/GTI/Jetta/New Beetle/Audit TT 1.8T)
Turn the key on but do not start the car.
[Select]
[01 - Engine]
[Measuring Blocks - 08]
Group 060
[Go!]
[Switch to basic settings]
Once you do this you will see the top right display say ADP RUN. The TB adaptation is being done as soon as you switch to basic settings. You will see the values change and hear the TB cycle for the first few seconds then it will stop. Leave it in Basic Settings for about 30 seconds.
[Switch to Meas. Blocks] button and you're all set.
Be sure not to touch the accelerator and make sure the engine is NOT running when you do this!
There you go mate. Also, if your going to do this make sure the engine is cold
how much do the MAF sensors cost? ya reckon it might be worth changing mine as ive just done lambda and coilpacks?
