washer level sensor
processpaul
103
Brighton
Has anyone fitted a level sensor yet.
Was wondering where to find/look for the cabling for it. guess under the belly or under the wheel arch cover??
klawit
ALTEA 1.4 TSI 4YOU (my2015)
Oct 13, 2005
477
10
Germany, Cologne-Area
hello processpaul,
to cut a long story short ... I've already posted some infos along with a retrofitting guide from our German forum in the neighbour-board ;)
(see "w w w . s e a t f o r u m . n e t/forum/showthread.php?t=65992" ... just eliminate the blanks)
=> Windscreen washer sensor
Hope you'll manage.
Klaus
processpaul
103
Brighton
Thanks alot Klawit
only just found that site today and just found it
Looks more complicated than expected. Was hoping not to have to take the instrument panel out....oh well just have to live without it...
Thanks anyway.
Wilkip
86
Hello
Looked through the instructions but couldn't work out what the part number is for the sensor.
Might be worth a go if i could get the sensor !
Already had the dash apart to get a few bits off the IP.
klawit
Oct 13, 2005
477
10
Hi Wilkip,
though I didn't refit this myself yet, all ALTEAs are said to come already fitted with the sensor as it's standard ... only the cables are missing and the ECU setting hat to be activated.
That's why there is no partno. mentioned in the instructions.
This is confirmed at least up till modelyear 2006, as several members in our forum reported successful refitting ... but no infos on my07 yet.
greets ... Klaus
Wilkip
86
Klaus
Thanks for that info, i'll have a look if its fitted...
Whats the bit about the "ECU setting " sounds like a dealer thing ?
Rocco
Last month i was going down to the airport (2 hours away) and the washers ran out. It was a dirty day and when i hit the wippers and found no water the dirt on the windscreen made visabilty very bad.
And if the sensor is there and SEAT couldn't come up with the cost for two wires to run to the IP then its a very sad day for SEAT.
Wilkip
86
MMMMMMMMMMmmmmmmmmm will have to consult the dealer if they're prepared to do this? Before I start taking the car apart....
Cheers for your help!!
