hi mikey.
Dont panic, had this alot in the past.
Simply the TCS gets confused, no maf faults there. Dicky switch contacts as my hazards used to do it also, its not a on/off switch as such (dont ask me why) its a push switch.
When you switch engine off and back on, it will prob work as normal.
I think we can all confirm that the cars an animal! Looks very sexy.
Will get some pics at lunch... will let you know about TCS light, if not perhaps a battery reset will help, will do it tonight...
Just speaking to previous owner, he says Fascia has always remained lit, and battery was never flat even after a week of the car being parked in his garage... still, my Blue Ibiza doesn't do it... so I doubt this one should be any different... I don't wanna have to keep pulling the fuse out, cos I lose all radio memory...
Mike
Can I log an IHI the same I would my K03s? Ie for MAF etc?
2 Pics... One just a cropped version from Advert.. the other is one of the guys from work has just taken and sent me... he is sat directly opposite it....GIT... lol
Mike
the back wheels look massive , looks like a drag car ,
They are std cupra rims mate.. However Mike is putting his TSW's on their, that he's currently got on the blue Ibiza.
Mikey car is a beast.... had great fun in it last night...
Zorst wasn't too loud when you went down the road this morning.
Am well pleased :D:D:D:D:D
will his wheels fit over the brakes its got on it seli? or has he had to use spacers with the cupra rims for the wilwood brakes on there at the min???
Well the cupra rims, shouldn't.. i am assuming that Rob put spacers on it.. but TBH I dunno mate..
Mike's TSW's should be OK.. but we'll find out.. lol
:lol: yeah im sure everything will be ok ;) he was like a little kid at christmas last night when we were speaking on msn :lol:
At least it was only on MSN mate.. Flash and I had the 2 hour drive to get the IHI then the 2 hour drive home with him like it....
I was out like a light when we got back... but him.. hell no.. still bouncing off the walls... I dunno lol
car sounded the nutts in Hatfield tunnel tho.. i tried to record it :( just got wind tho :(
I bet you wasnt complaining though being in the passanger seat though?
Pics from Lunchtime... picked up some competition mesh from Halfrauds too, £22, near on perfect match to honeycomb....TCS light still on, check MAF connection, seems fine. Noticed a kink in hose coming from top of DV, so have re-routed it and no more kink... will find out later if that was causing a bit of flutter...have left fuse IN for Radio fascia, will see if battery is OK later lol
Seli don't go home till I call you!! May need jump, but am 80% sure it'll be fine...
TSW's will fit no bother I believe, with Willwood brakes the Cupra rims fit, although this has 20mm spacers on the rear...cheers for comments guys ;)
Mike
That looks phat :clap: I don't know how low your last cupra was, but I'd say watch out for those speedbumps, curbs and multistory carparks, as that LCR splitter is sitting real low to the ground with the suspension so low. How many times did you have to fill up already ;) ?
