I did half the car in Autoglym Resign Polish and the other half in Zymol, the resign went off after about a week and a half, where as this is still fairly strong.
Fish
My Collinite 476 does not last very long, and I have about 4 coats. I think I need some sort of rotary / buffer to apply the wax and buff off, its too hard by hand, perhaps I need to warm the wax up first?
The beads arnt too bad, quite big, but most of thats down to the surface dirt affecting how tight the surface tension is.
Once washed, the beads will become tighter than shown.
I had similar sized ones on mine after 3 wks of no washing, & that had Collinite 915 over Jetseal109 on it
Think the problem is that I am applying it too much, I have used 3/4 of a tin since Feb.
Trouble is buffing it off, it kills my arm, so probably am putting too much on.
What's the Jetseal like to apply and remove? Is it a shade only job?
I ask as I really struggle for shade at car washing time where I live.
I cant really say, I only ever detail the car indoors, I guess as long as its not direct sun you'd be ok.
Where do you get it from?
Also, would it go on after a polish, and then you could add wax on top if needed/wanted?
