Shouldnt really be that smokey with a hybrid unless the map is overfueling low down.
If you're contemplating the TD2, then consider something a bit bigger than the VT2.The TD2 is a VNT20 based turbo, and the VT2 is a VNT17 based turbo. For comparability you want to be looking toward the VT4 from Allard. The VT2 is more like the stage 1 turbo from TD.
Anyone know if its possible to 'overspec' the turbo for reliability - e.g. get a bigr turbo then needed and undertune it a bit rather thean get a VT2 or Stage 2 and max it out?
My VT2 from Allards only lasted about 6.5k - it was replaced but not under warrenty. The new turbo was remapped for more midrange & less top end power, the drives nicer now & smoke is much less than before - hopefully it should last longer than the last one!
