Beeps
Jib
496
31
Doncaster, South Yorks
Over the last week my car has been making beeping noises from around the fusebox area. Now at first, i thought it was me going crazy but it does actually happen.
Was out with a friend in the beeza tonight and ive figured out how to make it beep. If i go round a roundabout alittle too fast and the arse end starts to step out.....it beeps twice from the fusebox area. It also beeps once depending on how fast i go.
Now ive looked round the forum and i cannot find anyone with a similar issue:shrug:
What do we think its is?
Czechboy
Tarmac terrorist
Apr 14, 2005
1,607
Hampshire
Is it a beep (like a horn) or more of a buzz (like an electrical short) kinda sound ?? Maybe Pedro fitted your car with a ESP (Espaniol stability control) which consists of a mouse in your fuse box and if you push the car too much and its about to slide then the mouse gets scared and beeps to warn you ;)
Mig
beezertart
**MAYHEM**
Sep 11, 2007
1,260
beyond the sun
do they have a low oil pressure buzzer? my golf did. you my be low on oil
My golf had this but was more like a big buzz as the ex found out when it started one nite in the dark screaming at him,thought it was low on oil so chucked some in,noise carried on chucked in more for multiple reasons,he's not normally useless with cars but managed to flood everything with oil basically n cost me lotsa pounds to put right.Was all down to the oil pump had seized,hence the alarm kicking in,only over 2000rpm tho i think:confused:....how does something that's covered in oil seize?????
Read something on a thread the other day about beeps,will see if can find it again but prob irrelevant..............
Jib
496
31
Its turns out that yes, i was dangerously low on oil.
Is this a standard thing on the ABF that went in the Ibiza's and the Golfs or just the Golf?
If its the latter, something tells me mines had a engine change at some point in its life!
beezertart
**MAYHEM**
Sep 11, 2007
1,260
beyond the sun
Probably one of those things you don't know you've got til it kicks in.....never had a clue with mine!!! if oil was dangerously low why was it not buzzing all the time rather than just round corners when it obviously dropped below sensor level or whatever.....
Can't see anything in the Haynes about it...
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
never heard it in mine
but then mines never low on oil ;)
in fact mine rarely gets the oil dirty anyway
