Jace
Sneaker Freaker
Finally got round to fitting the H3 Night Breakers in the Fogs at the weekend
Side lights: W5W/501 - Osram Halogen Cool Blue
Dipped : H7 - Osram Night Breaker
Fullbeam: H1 - Osram Night Breaker
Fog lights: H3 - Osram Night Breaker
Side & Fogs (Chav'tastic)
Dipped & Fogs
Main & Fogs
I have just fitted a full set as well, and to be honest am dissapointed at the dip beam, throws a lot of shadows around and the light is cut off very sharply, you can see a line on the road where they end, full beam is impressive though, but there is still a few shadows which come from the headlight glass ??
Wouldn`t reccomend them tbh guys !!
What are they like to fit? Unless mine turn up tomorrow I will be fitting the bulbs myself (if they turn up tomorrow the dealer will do it for me)
What are they actually like driving, it is near Xenon standards?
Cant give a 100% answer as I've never had xenons, but they are much brighter & whiter than OEM fitted bulbs
Really :confused: I found them brighter than the Philips I had in, maybe your lights need setting if they have such a sharp cut off ??
Fitting is quite simple, use a small mirror (womens make up size) to get a look inside the lamp, helps a lot. Also, small hands help too.... I'd do the none battery side first, more room to get an idea of whats what.
Takes about 15 minutes to change all the bulbs
Fogs are easy, 1 screw takes the outer grill off, plus a few clips, so take it slow else you may break one :whistle:, 3 torx hold the unit in.
Time was about 5 min a side for these.
did you fit them with right side up? The notch should point upwards if I'm not mistaken...
