exactly.....
You'll wish you did a better job when you're stranded at 2am in teh rain having clipped a speed bump ripping that pipe off.
There's better routes to put the pipe
yeah i did have to buy new jubilee clips because they were too small, gold, and way to soft. Have spoken with dan and he is refunding me the money for them. yeah my pipes are done better than that but they dont go behind the intercooler. They sit higher than the sump and higher than the front bumper plus the route is shorter. It just goes straight back from the front. No bends or joins, I finished it today and i can defo feel a big difference but i have no idea how to do logs. So rhys is going to help me do that soon. Will post them once they have been done.
Done it...Man What a better way this was..
Also am i right in thinking that the Shorter the IC pipes route the better? Im sure i read that some were..
Well it was at the bottom of the sump..So it was kinda Level with the bottom on my LCR splitter..
Ive done it this way as i found it alot easyer and its alteast a 1ft Shorter .. and is 3'' 1/4 higher than it was Before.( I Measured it) I just need some Metal cable ties now but it will do for now..
pics:
This were i got the 1st idea from:
you did that quick. Well on the left as u look at car front on. Mine comes down 90deg then 90deg but twisted and straight back to where it goes up. Its jammed in tight and runs up against chassis. And like i said my sump is lower and so is front bumper.
thanks for the replies folks.
im still looking at either this one or the forge one as the 2 ill choose between.
quick Q,
how does the ic attach to the crash bar? it looks like it hangs on screwed rod?.
cheers
yeah it is attached by threaded rods. i have 3 on mine and big a** sparcer's in between. mine aint going no where. plus i havent cut the front out of mine, i still have the center section of the bumper
myki if u want u can. It is alot higher than that now due to me actually tightening it up. But yeah go for it. I will add the finished product later as well.
