Jameze
179
Up Aberdeen Way
Soz fr the repost but i need answers. All im tryin to find out is how to remove the wiring from the seat ibiza 1.8 GTI. I removed the ecu from the bracket and the security clip on the wiring but im left with this!
Here is an image for ya...i have snapped the bracket slightly but seems ok, jus cant work out the release mechanism. If you look carefully you will see four pins holding onto the wiring therefore my problem. stupid ecu lol.
From what i remember the (and i've just been out and looked to double check!) there is a 2 pronged clip that is very chuky on the end that points towards the drivers side headlight (when fixed in the car).
You push then together and slide out, it does come out a long way but as soon as you do (it will click from memory) you can remove the plug and harness from the ECU.
Hopefully that helps!
Thanx mate spot on....was hopin someone would get back lol i spoke to a mechanic at seat an he said summin similar to u but urs was more detailed lol :)
