sagitariusim
I'm driving CUPRA, factory recommends Repsol motor oil. Did someone recommends some other brand which will suit better for the CUPRA engine.
Thank you.
Thank you.
I use Castrol Edge. 0-30W
I took my car to the dealer to change the oil and they puted Castrol 5w40, 504 00 .
Is this the correct oil? Some friends are telling me that it`s the wrong oil and it should be a 0w30...Seat garantees that they puted the correct oil...I`m confused!
cheers
Sounds right to me if you have a petrol Leon but to be sure check on here:
http://www.castrol.com/castrol/iframe.do?categoryId=9024084&contentId=7044829
It does a search on your registration number.
cheers
I was mistaken! The oil they puted is a Castrol 5w40, but with reference of 505 01. Again, i have a 2008 leon cupra.
Yes! I checked the receipt of the dealer. I`m confused, because in the manual says this is diesel oil, but seat says it can be used in diesel and petrol...You sure this is correct?
Yes! I checked the receipt of the dealer. I`m confused, because in the manual says this is diesel oil, but seat says it can be used in diesel and petrol...![]()
Hmmm... That's the same as happend to me.
I don't want to go into too much detail on a public forum, but if you want more info send me a PM.
Spill, im interested to know......dont have to tell us any names..
Okay, but before I start I'll point out that the dealer did resolve the issue free of charge, so a plus point to them for this.
When the car had done about 4000 miles checked the oil and it was on the minimum so researched what top up oil to get. The answer that cam back from both SEAT and Castrol was that it needed to meet or exceed the spec I mentioned earlier. Went to Halford bought some Castrol Edge 5W-30 I think it was that met one of those specs, job done.
Took the car for the 10K service and noticed as I was leaving that the topup oil they put in the boot (and sneakily charged for) was Catrol Magnetec 10W-40. Thought they must know what their doing and put the right oil in so just went home.
Later in the evening was checking the invoice and noticed the oil spec was different think it was 505 01 so I checked the top up bottle and that was the same.
Posted a question on this forum and a couple of people said that didn't sound right. Next day rang SEAT first thing and eventually persuaded them to confirm with the technical department if it was right or not.
I then got a voicemail saying that they had checked with the technical department and that was the wrong oil for my car, it would not cause any damage to the engine but the car would need servicing more frequently.
Rang up the dealer and they were adament it was the right oil for my car and after a while saying I was really not happy they checked with SEAT and said they would change the oil free of charge. It has almost got to the point where I needed to go and play the voicemail from SEAT back to them.
Apparently the system they have isn't clear on which oil should be used. I checked in the handbook and that matches what SEAT told me originally.
