samndavid55
please someone help i have recently brought a lcrand i have found out that when i lock it with the remote it does not lock the drivers door it locks everyhing else i have disconnected the battery for about 40 mins but still the same if i lock it with the key all the doors lock fine but when i open it sometimes the alarm goes off any help would be great many thanks david
hi i have searched everywhere but can only find faults where the drivers door is the only one that works so i am lost any other advise
maybe try locking it with the key,
take the door card off and have a look for connection bars loose.
lock from the inside to see if there is any noise on that door for motors working in the door.
few ideas.
i can hear it working in the door if i use the key it all works fine
Id guess it could maybe be a fault with the central locking actuator on the drivers door lock. When you lock it with the key and unlock with the remote does the drivers door unlock?
am i sounding completly stupid but could you explain it more also do you know how to programme the remote as i have not got the owners manual
no it will not do anything to the drivers door with the remote works everything else
ok is there a way to check/fix it? thank you so much for your help
I'm not sure if they come as a seperate actuator or whether its integral to the lock but if its broke then it will need replacing. It's possible its not that but to me it seems the only logical thing before getting into the realm of weird faults.
if you can get at the plug on it and find out what pins it is for the actuator you could check the signal, a lot to try though. If i was you i'd get a door lock/actuator, get into the door and just plug the new one onto the wiring loom as a test, operate the locking, if it locks then bingo.
sounds like it could be expensive i only just got it 3 weeks ago and alredy costing money thanks for all your help
I had a very similar sounding problem just before christmas - use advanced search on my name and you will find it. If you tap the door around the handle will it start working(lock with button)/does it look sometimes but not others? If it does could be the door control module - basically there prone to letting water in and the solder cracks on the circuit so pressing the button doesnt get the signal from the module to the lock. Its a £92 quid part from your main dealers and £180 ish if you want it done by a dealer. I did mine myself took 1-2 hours being cautious and wasnt overly difficult bar droping the lock retainer(see the thread i mentioned searching) which was a half hour in itself. Any questions feel free to PM me.
Adam
