Do you run a AFR gauge Dave?
What kind of AFR readings would i be looking for once i have me gauge installed and running the meth?
No, Id like to fit one sometime, but I rely on regular logging with vag-com. Block 31 on a Leon gives its wideband lambda.
Depends on your mapping, but you'd be looking at your a/f dipping towards/below 11.0 as evidence you're burning the methanol.
Ibiza`s only have Narrow band,Dam you leon owners!
Looks like i need to get myself a AFR gauge then, would you adivse against changing any timing settings before gettig the AFR fitted?
I think that once you take a car beyond stage 2 - by whatever means - you really should know exactly what's going on with your fuelling.
You could advance timing a little bit by checking CFs, but I'd advise against large increases before you get an a/f meter.
I'm fitting a safety device which will cut my boost if the methanol stops flowing.....
Thanks for that Dave, advice taken on board and wont be ignored, what kind of increase would be acceptable without the AFR gauge do you think?
I have the float switch with my install with a warning LED for when it gets low, im going to install a On/Off switch for the pump for when the meth runs out and just stay off boost until refilled.
Say 4.5 degrees? :)
Thanks Dave.
I`ll be getting some logs tonight, just didnt have time yesterday :(
What things would i be looking for when logging to determin if i need to change down a nozzle size?
Also is best to have the controller to start spraying as low down as possible without bogging it down?
Odd misfires top end under load. The thing is, you don't notice - there's just too much methanol in there. It reduces my torque.
Yes, if you can get some methanol in while it's spooling, good, but it will bog down if it's too low.
What recommendations would you make if you're running on water only?
I have an LCR with a hybrid k04 that runs max boost of around 27psi and holds around 18psi to the redline.
I have the nozzle fitted just after the forge fmic (behind the foglight) and I've set the controller to start at 8 and on full at around 18. Nozzle I'm using is a D03 (189ml per min)
WMI running would see right - have you got logs of intake temps and CFs? I'd use an mbc to calm that boost spike, things have got to get hot from that...... :)
Sorry its taken so long, but here they are at last.
003+020
Could sombody explain what the ign timing figures mean and what i should be looking for.
Code:
Monday	7	September	2009	20:01:54
6K0 906 032 AA 		1.8L 20VT EU3    01 0002
	Group A:	'003				Group B:	'020
		RPM	Mass Flow	Load	Ign. Timing		Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization
	TIME					TIME
MARKER	STAMP	 /min	 g/s	%	°	STAMP	 CF	 CF	 CF	 CF
	0.01	1680	27.72	100	12.8	0.4	0	0	0	0
	0.8	1800	33.22	100	13.5	1.2	0	0	0	0
	1.6	1920	38.53	100	12.8	2	0	0	0	0
	2.51	2040	46.92	100	12.8	2.91	0	0	0	0
	3.31	2200	52.25	100	9.8	3.71	0	0	0	0
	4.11	2320	64.33	100	6	4.51	0	0	0	0
	4.91	2480	81.97	100	6	5.31	0	0	0	0
	5.71	2640	98.72	100	6.8	6.11	0	0	0	0
	6.49	2880	107.25	100	8.3	6.89	0	0	0	0
	7.29	3080	102.86	100	9	7.69	0	0	0	0
	8.09	3280	114.36	100	9	8.51	0	0	0	0
	9.01	3480	125.67	100	9.8	9.41	0	0	0	0
	9.81	3680	133.19	100	11.3	10.21	0	0	0	0
	10.7	3920	139.61	100	11.3	11.1	0	0	0	0
	11.5	4120	146.11	100	11.3	11.9	0	0	0	0
	12.32	4320	163.86	100	11.3	12.72	0	0	0	0
	13.21	4520	169.28	100	12	13.71	0	0	0	0
	14.11	4760	174.58	100	11.3	14.49	0	0	0	0
	14.91	4960	183.92	100	10.5	15.31	0	0	0	0
	15.71	5120	192.75	100	9.8	16.11	0	0	0	0
	16.51	5240	197.44	100	9	16.91	0	0	0	0
	17.31	5360	200.31	100	8.3	17.71	0	0	0	0
	18.11	5520	201.14	100	8.3	18.51	0	0	0	0
	18.91	5640	204.81	100	8.3	19.31	0	0	0	0
	19.71	5720	206.86	100	8.3	20.11	0	0	0	0
	20.51	5840	206.89	100	8.3	20.91	0	0	0	0
	21.31	5920	210.69	100	7.5	21.71	0	0	0	0
	22.11	6000	213.53	100	7.5	22.51	0	0	0	0
	22.91	6040	214.25	100	6.8	23.31	0	0	0	0
	23.71	6120	213.19	100	6.8	24.11	0	0	0	0
	24.51	6160	212.83	100	6	24.91	0	0	0	0
	25.31	6200	211.75	100	6	25.8	0	0	0	0
	26.3	6240	212.47	100	5.3	26.81	0	0	0	0
	27.21	6920	3.19	9.4	36.8	27.71	0	0	0	0
	28.11	4800	192.53	100	10.5	28.51	0	0	0	0
	28.91	4720	4.19	2	14.3	29.4	0	0	0	0
I havent advanced the timing yet, im going to advance to 4.5degs as dave stated and re-log, i doubtful if ill see any movment, currently running 25% meth.
Seems to of helped my intake temps no end, although as not as low as they could be with a better FMIC its a vast improvment.
Code:
Monday	7	September	2009	19:57:49
	Group A:	'118
		RPM	Temperature	Load	Absolute Pres.
	TIME
MARKER	STAMP	 /min	°C	%	 mbar
	0.01	1680	26	95.3	1250
	0.42	1760	26	95.3	1280
	0.82	1800	26	95.3	1310
	1.22	1880	26	95.3	1330
	1.71	1960	25	95.3	1370
	2.11	2000	25	95.3	1400
	2.51	2080	25	95.3	1440
	2.91	2160	25	95.3	1480
	3.31	2200	25	95.3	1540
	3.71	2280	26	82.4	1620
	4.11	2360	26	78	1710
	4.51	2440	26	75.3	1860
	4.91	2520	26	76.1	2040
	5.31	2600	26	70.2	2230
	5.71	2720	26	63.1	2370
	6.11	2800	25	54.1	2450
	6.51	2920	25	43.9	2440
	6.91	3040	25	37.3	2340
	7.31	3160	25	32.5	2240
	7.81	3280	25	33.7	2190
	8.21	3360	26	34.9	2200
	8.61	3440	26	35.7	2220
	9.01	3560	26	37.3	2220
	9.41	3680	27	37.3	2240
	9.81	3760	27	36.9	2280
	10.21	3840	27	37.6	2240
	10.61	3960	27	38.8	2230
	11.01	4080	28	41.2	2230
	11.41	4160	29	43.1	2270
	11.82	4280	29	43.5	2280
	12.32	4360	30	45.5	2280
	12.72	4480	30	45.9	2310
	13.12	4560	30	45.5	2290
	13.52	4680	31	45.9	2270
	13.92	4760	31	45.9	2250
	14.32	4840	32	45.9	2260
	14.72	4920	32	45.9	2240
	15.21	5040	32	45.9	2240
	15.61	5120	33	46.7	2230
	16.01	5200	33	47.5	2220
	16.41	5240	33	48.2	2250
	16.81	5320	33	49	2240
	17.21	5400	34	49.8	2240
	17.61	5480	34	51	2230
	18.01	5520	34	52.2	2230
	18.51	5600	35	54.5	2250
	18.91	5640	36	55.3	2260
	19.31	5720	36	57.3	2270
	19.82	5760	36	76.5	2290
	20.22	5840	36	78.8	2410
	20.62	5880	37	77.3	2420
	21.02	5920	38	76.1	2400
	21.42	5960	39	74.5	2380
	21.84	6000	39	72.5	2420
	22.32	6040	39	70.6	2390
	22.72	6040	39	69.4	2360
	23.12	6080	39	68.2	2330
	23.52	6120	39	67.1	2340
	23.93	6120	39	65.9	2330
	24.41	6160	39	64.7	2330
	24.81	6200	40	63.9	2330
	25.21	6160	40	62.7	2330
	25.61	6320	41	61.6	2310
quick boost log, anybody think it looks abit iffey where the boost drops and pickes back up again?
Code:
Monday	7	September	2009	20:05:33
	Group A:	'115
		RPM	Load	Absolute Pres.	Absolute Pres.
	TIME
MARKER	STAMP	 /min	%	 mbar	 mbar
	0.01	2320	141.4	1880	1700
	0.41	2480	168.4	1950	2040
	0.92	2600	180.5	2010	2290
	1.42	2720	191	2070	2450
	1.81	2840	191.7	2110	2410
	2.21	2960	188.7	2140	2310
	2.61	3040	184.2	2170	2230
	3.01	3120	182.7	2180	2180
	3.41	3280	185.7	2210	2190
	3.81	3360	188	2200	2210
	4.21	3440	189.5	2220	2220
	4.71	3560	186.5	2250	2240
	5.11	3680	187.2	2260	2260
	5.53	3760	188	2260	2250
	6.01	3920	184.2	2260	2220
	6.42	4000	186.5	2260	2230
	6.82	4120	187.2	2260	2260
	7.22	4240	191	2250	2290
	7.72	4360	190.2	2250	2290
	8.12	4480	190.2	2250	2290
	8.52	4560	191.7	2250	2270
	8.92	4640	191.7	2240	2280
	9.32	4760	191.7	2230	2280
	9.72	4840	191.7	2210	2250
	10.12	4920	191.7	2210	2240
	10.52	5000	191.7	2210	2250
	10.92	5080	191.7	2220	2260
	11.32	5160	191.7	2230	2230
	11.72	5240	191.7	2240	2250
	12.21	5360	191.7	2250	2240
	12.73	5400	191.7	2270	2250
	13.13	5480	190.2	2270	2280
	13.52	5560	190.2	2290	2260
	13.92	5600	188.7	2300	2260
	14.32	5680	189.5	2310	2260
	14.72	5720	188.7	2320	2290
	15.12	5760	189.5	2330	2270
	15.52	5800	188	2330	2280
	15.92	5840	187.2	2320	2280
	16.32	5920	186.5	2300	2280
	16.82	5960	183.5	2290	2320
	17.22	6000	185.7	2280	2340
	17.62	6040	184.2	2280	2300
	18.02	6080	185	2270	2280
	18.52	6080	182.7	2270	2270
	19.01	6120	182.7	2270	2280
	19.41	6160	183.5	2270	2290
	19.81	6160	180.5	2260	2280
	20.21	6160	180.5	2260	2310
	20.61	6200	182.7	2260	2300
	21.01	6200	178.2	1930	2320
	21.41	6160	14.3	990	1720
I maybe barking up the wrong tree here, but can the spring in a new actuator get softer over a period of time causing a small loss off boost, i`ve currently lost a psi of boost with all pipes good and secure, i know that cranking the wastegate will get me my lost boost back but i dont just want to cover the problem.
Your boost is pretty stable there. (requested, actual).
Good logs. Column 5 in 003 shows the amount of ignition advance (before tdc) that you are running. It's here that you should see improvements if you advance your timing.
What should i be looking for in terms of improvement?
Basicly all i can do now is advance the timing to 4.5deg and relog, until i go to see billwith his wideband?
Any idea on the spring getting soft in the actuator, just a idea i had, proberly the wrong one. lol.
Theoretically, advance by 4.5 degrees and that should increase the numbers in that column by that amount. (but it doesn't, due to sampling rates of vag-com and that timing advance swings back and forth as the ecu tries to meet requested loads).
I'll pass on the actuator spring question (I don't hold with most of the stuff that's talked about fiddling with actuators and springs :D )
Plenty of duty cycle left in the n75 valve to make more boost, its a case that the map isn't requesting the boost you want it too. Actuator spring is good ;).
Good to see that with wmi activated your cf's are nil, extra power waiting to be unleashed.
Keep the car, get some rods in there and up the boost.....happy days.
map is asking for exactly the same 'airflow' to achieve the torque request, achived via boost... so denser aircharge, cooler weather now, will all have an effect. Map does not change, ambient conditions and mechanicals do
people continue to get fixated about the boost.. ME7 does not run fixed boost requests, an external EBC will, ignoring ambient conditions, where the Me7 is trying to compensate for the ambient conditions and sensor inputs its seeing.. MAF g/s, AIT 'C, MAP pressure kpa etc etc
An actuator can relax, and adding some preload can recover this (shorten the rod length)
So if i understand this correctly.... so long as the n75 valve is the sole means of boost control the ecu will adjust the boost up and down to make the same specified torque request which is measures by evaluating the mass airflow.
If i make modifications to my car and don't see a significant increase in performance or mass air flow it could be because the map is winding back boost or injector duty cycle since the car is making the same torque only with less effort. A map adjustment would be required to see the modification benefits.
Am i on the right track here.:shrug:
yep, when ME7 is adjusted to still run this control thats what it should do...
however, the ecu can be made to ignore some of these tables, and get driven to do as its told settings.. depends on how its mapped.
I mention it as there is the fixation on boost by most people, but its not the primary ecu setting, just a function used to achieve a load setting. Its not a 1:1 thing, which is why it often seems variable, as vairable as atmopheric and weather conditions in fact. AIt's, EGT's all factor in compensating tables, which makes it difficult to tell exactly whats cause and effect at times.
I like my stand alone DTA a lot, as it does what its told, and does'nt think so much on its own.
So what if you do throw in an EBC into the mix, are any other parameters affect? Are any timing or fuelling pulled back due to the fact an EBC is in control of the boost?
For instance, if you hit limp mode for whatever reason would anything actually be affected or would you just see a light on the dash as the first noticeable thing in limp mode is lack of boost, but with an EBC you wouldnt see this.
