ARL PD Engine - Why do they eat cams?
mentalmechanic
86
Hi all. Had my FR TDI for a month or so. Done 3K miles no probs, car done 62K. Heard slight tappet rattle tonight. Although a few I test drove, before I bought one, sounded a bit tappety until it was warm. Mine hasnt made any tappet noise really until tonight. And it was only slight and only about 70 degs on the gauge.
It was registered in Jan 2006, last of the MK1's on a 55 plate.
I know about the cam issue on PD lumps. Does anyone know why the 150 ARL seems to suffer more than the other engines with cam wear?
And I've also read somewhere that VAG started putting hardened lifters in at some point?
AND......should I be concerned at a little tappet noise yet? The car runs fine still.
Cheers.
techie
Skoda Techie
Mar 22, 2003
5,438
Worcs
They fecked up from what I recall and a batch of the tappets werent hardened, this let to them wearing out and taking the cam with it.
Cupra Ross
Breaks things............
May 15, 2005
1,379
Edinburgh, Scotland
Its not just the ARL, ASZ has similar problems but only up to about 2004.5 IIRC. They're not immune to issues just because they've had PD oil all their lives, I have a friend with a Bora Sport PD TDi 150. He bought it at 70k miles and it had been serviced with the correct oil (receipts to prove) from new and at less than the specified interval. 3 weeks later, it cost him over £1300 for a new camshaft.
mentalmechanic
86
Yes it was definitely a lifter making the noise. I'm a mechanic by trade although mainly Vauxhall. Drove it to work this morning and the noise had gone.
That was mainly my query to be honest, if they can have a sticky lifter every now and then, because I am wary of the cam issue. People say about the dreaded ARL engine eating cams but I can't see why they should do more than the lesser powered PD's unless they are made with different parts or something.
I know I could have a look and take the cam cover off but just want to get to know the engines traits really.
Cracking car though and really impressed with fuel cons when not caning it!
Jan 22, 2007
2,074
some may say lala land....
this has been very well discussed in the tdi section
pointed to the reasons as noted above and other threads on tdiclub & mkiv to have a read through.
mine is borderline june 04 and not happened yet, but lots of digits are crossed
Jan 22, 2007
2,074
gavin,
no idea if can check or not.
have thought about it a couple of times, but just have a feeling stealer would deny any knowledge of their every being an issue.
as kinda proven by cupra ross friend with the bora; receipts for correct oil since day 1 and still had to pay £1300. if it was accepted you'd have expected vw to assist in some towards cost.
Cupra Ross
May 15, 2005
1,379
Edinburgh, Scotland
Pete got no assistance from VW whatsoever when this happened to his. Apparently it is reasonable wear and tear as the car had over 60k miles on it. If its going to happen, it will. There's not really any point in worrying about it.
mentalmechanic
86
Its a shame, its the sole factor that stops me from buying a higher mileage PD150. Great engine otherwise though and the newer Common Rail Engines should be very reliable.
You say about higher mileage 150's. I've read that some people have had over 200k out of PD's with no cam issue whatsoever. But they generally are the lower output engines. But loads of people have had trouble with 150's. I know that 130/110 etc can have it also, but does anyone know why the 150 seems to suffer more than most?
Sorry to keep pushing for this but it is interesting for me, and there must be a reason for it!! If anyone finds any links it would be much appreciated as I'm not that good at searching about, it seems, as you guys sound like you are!!
Again, sorry for going on!!
Cupra Ross
May 15, 2005
1,379
Edinburgh, Scotland
You can be lucky and get a good ARL engine that will last the distance. The other PD engines aren't immune (110 is Bosch VE, not PD and as a result is not affected by this issue).
Did you miss this post?:
princess09
Hello,
Can someone tell me does the BPX engine suffer from the same Camshaft wear as the ARL?
