niki
having problems starting when hot or cold, cranks over fine then eventually starts ok ,this happens 2 or 3 times a day now.I have checked DTCs none present car runs fine when going have cleaned throttle body and car has had new plugs and coils last month. could this be a temp sensor fault? or a map fault? any ideas would be great i work in a toyota dealership! thanks
problem starting
hi thanks for help, the battery doesnt go flat it cranks fine but doesnt always start,im thinking it may be the halo wire around the ignition barrell, but does the key light flash on and off on the dash if there is a prob? any input would be great thanks
if its the battery the cells are foooked meaning all the jump packs in the world wont make any diference
