Not had very good experiences lately....
Usually I service the car myself but thought I would get a proper job done and chose AMD to do my service as I had heard good things about them.
During the service they found the sump nut was spinning and couldn't remove it. So they heli-coiled it and put a new plug in there and told me it was fine and not leaking oil.
Two weeks later I check my oil level as Im about to go on a long drive and it doesn't even come up to the indented part on the dipstick
Look under the car and the sump is dripping oil![Furious [:@] [:@]](/forums/styles/seatcupra/oldforumsmileys/furious.gif)
Also I read you should put 5w30 fully synth in the LCR but on the invoice it says they used 5w40 semi synth.
They will be getting a call on Monday!
Second bad experience.....
Took the car to a local garage to get my tyres fitted, which they do for a fair price. A week later I check my tyre pressues and one is at 19psi, two at 22psi and one at 23psi
Should be 33psi all round, and there were two valve caps missing too !!!
Its booked in for £1500's worth of work at VAG Tune in three weeks time so they better not piss me off too!
Not happy at the moment. A new sump is £100 + fitting
Should be 33psi all round, and there were two valve caps missing too !!! Its booked in for £1500's worth of work at VAG Tune in three weeks time so they better not piss me off too!
