What and where is the Knock sensor?
NottsLCR
243
Nottingham
Had the car on VAGCOM tonight and it has thrown up 4 codes relating to the knock sensor. What is it and where is it?
I've read on google its purpose and the symptoms on Ross Tech just want a simple explanation of it and where it is.
The part seems fairly cheap if it needs replacing, I've been having problem with a loud ticking which is believed to be the cam chain tensioner but is this related?
DannyC87
Rubbing is Racing :-)
Mar 4, 2008
3,459
knock sensor detects engine knock, otherwise known as pre-detonation. This normally occurs when the timing is advanced too far for the modifications and petrol being used. Best bet is to log your CFs (timing correction factors) using VAGCOM to see if your knock sensors are giving realistic readings; your issue may be too much advance rather than a dodgey sensor.
NottsLCR
243
Nottingham
Cheers guys, I'll try to log this weekend but I have never done any loggingbefore so i'll do some reading first - As its to do with timing could be the cam chain tensioner then? Spark Plugs are fairly new due to the recent engine flood :(
Feb 26, 2009
5,275
Wolverhampton
I see from your signature that you have a hybrid fitted, do you have an appropriate map? I wonder whether the the hybrid could be messing up your fuelling and causing pre-detonation? Or is the ticking a recent thing?
Pyro
dont think the tencionor will have an efect my friend mines been gone for a while now and i get nothing :D
NottsLCR
243
Nottingham
Hybrid hasnt been mapped to suit yet as afew days after fitting the FPR failed (not believed to be related) and flooded the engine with petrol.
I've tried to get a mapped twice but both times something has happend, first cracked DP then the engine flood. Pyro im booked in Thursday to get this checked out so hopefully this is the cause and can get it fixed so i'll let you know after your help if its sorted
DannyC87
Mar 4, 2008
3,459
as said.. cam chain tensioner shouldn't cause pre-det IMO.. the suspect causes would be fuelling and spark timing.
NottsLCR
243
Nottingham
No misfire codes just the following:
17733 - Cyl.1-Knock Contr. Limit Attained
17734 - Knock-Control: Cylinder 2: Regulation Limit Exceeded
16712/16717 - Knock Sensor 1/2 (G61): Signal too High
DannyC87
Mar 4, 2008
3,459
sounds like something is causing predet rather than a sensor issue to me. Both sensors are suggesting knock..
DannyC87
Mar 4, 2008
3,459
Whats things would you check?
I cleared the codes so will see if there back tomorrow after my trip to work and back
Without a log of your CFs and fuelling I couldn't comment.
As you say, clear them and they may not come back. If I boot mine from cold (not that I would under normal circumstances) I get a load of knock errors..
Pyro
as said log your CF's i think its 20 and 03 change plugs what fuel do you run?
