FenlandPosh
I will order a temp sensor from seat tomorrow and give that a try. The car is due a service, so I also will order a fuel and oil filter.
I can't see any loose pipes etc, but at the moment i have a painful trapped nerve in by shoulder/neck, so I am not up to doing too much with regards investigation work.
Would the maf cause the oil pressure light to come and the warning beeps, and prevent the car from starting and cause the black smoke?
As above, i will try the temp sensor, give it a service and cross my fingers (very tightly). Even if it needs a maf, I wont begrudge paying for that if it resolves the problem.
You just need to be careful not to replace a load of parts that are absolutely fine and waste your money. Your best bet is to get it onto proper diagnostic equipment and find out what it actually is that's causing your problem. There are a lot of mobile companies who can do it but be careful as there are also a lot of mobile companies who don't know what they're doing.
