VCDS lite was never going to read the faults as this is a newer can based car I believe. Correct me if i'm wrong though. It does point to an immobilizer fault to me too, starting and then cutting out soon after.
If you look back at the original post though you'll see that the car wouldn't start then cut out, it just wouldn't start.
Update: A mechanic checked the car today. Some good news, he started the car (that was a relief), but it was running lumpy. I hadn't put the hose back on properly that MJ suggested i disconnect, and the mechanice was also unable to reconnect it (he said they had a special tool at the dealers to reconnect it?).
The car wouldn't start a second or third time, without the mechanic taking one of the relays out and wacking it. He however, didn't believe that this was the cause of the problem, and said that there was no point in me buying a replacement relay at this point.
The dash lights were doing there own thing, and most stayed alight even when the car was running. The oil pressure light was flashing for about 5 mins when the car was first started, but that went off, and the brake light (i) was flashing some of the time.
Iniitially the engine management light wouldn't come on, but then it came on, and stayed on when the car was running. He got the same code as me when he did a scan (P0600), which indicated a comms fault.
He said that the car needs to go to seat for a full scan. He wrote: No EML & ECM fault.
The mechanic said that I shouldn't drive the car (even if i can get it started). I have a skoda dealer close to me, and a seat dealer miles away, so would the skoda dealer be able to do the same scan as the seat dealers, or am i best off getting the car towed to the seat dealer?
Thanks for advice you guys have given me, and although the car is still stuck on the drive, at least it doesn't have a blown engine. I just hope it isn't going to be a big issue tying to find the cause of the problem.
The mechanic further said that the ECU may just require an upgrade which often happens with VW engines?
Although
If you have a code reader try to access the ecu if you can't then the ecu power relay has failed, if you bang the relays under the drivers side of the dash or in the fuse box in the engine bay the light might come back on and the car start.
Then you'll need to replace it.
