nice looking rim that - plenty of colour combo potential too
are they not available handed though ?
There my favourite rim and I was going to get them but going for a different look now , also they should be 8.5 j fronts and 9.5 j rear not 8.5j all round , presume you will run some stretch with these ? If you have an Lcr they may require spacers as well trial and error tho
yeah theywill be going on my LCR :/ :/ Im icking them up this weekend :/ :/ :/ Hopefully spacers are not needed lol.....
woooo wweeee!! those are PRETTY!!! Im looking at new options - mates offered me his anthracite BBS CHs but I want something different - BBS has been done to death IMO. So been looking at Porka twists, but way outa budget! but those with the polished faces and then anthracite behinds on the mighty yellow would look amaizing! and different! :D Got my new idea - thanks mate! Post pix once they are on your waggon!! :D
Yes the off set Is different to your car you need adaptors all round 100 % so there like 200 quid ish then you may need spacers on top to clear the calipers on the front
You shouldn't need additional spacers as these wheels are ET35, your Leon is something like ET32 so these wheels will sit 3mm further inwards. This means that with 15mm or 20mm adapters the new wheels will sit 12mm or 17mm further outwards. The main problem will be ensuring that the spokes clear the calipers, with some luck this will be fine but if they are touching them you'll need to stick thicker adapter on, I wouldn't recommened putting a spacer on a spacer. Another issue you might have to tackle is the centre bore of the wheel, I have no idea what the standard VAG centre bore is but my guess is that Mercedes use a different one. If this is the case then you'll need to fit spiggot rings over your adapters to increase the size of your hubcentric adapter but should Mercedes use a smaller centre bore (no likely I would imagine) then you'll need to get the wheels bored out.
You will definitely have to buy rear adapters as well as the front, your hubs have a PCD of 5x100 and these wheels are 5x112, there's no getting away from that.
