Been thinking about investing in a snow foam set up for a while now but now with the car on the way it's going to be a must. Problem is i don't even have a pressure hose at the moment and can't afford to spend hundreds on that alone.
You want to buy Magifoam to put through the lance super thick foam that cuts through the grime very well![]()
Originally Posted by Edward101
"You want to buy Magifoam to put through the lance super thick foam that cuts through the grime very well"
Be cautious as a high ratio of TFR in the snow foam not only strips the dirt off but the protective layer of Wax/Polish and if its strong enough eventually the laquer on the paint. Not cool.
Leon20v: Ah thanks for that! Will save me a lot of money and don't mind having to use two coats anyway![]()
Is the snow foam instead of a wash, or is this as a pre-wash?
I thought it was a pre-wash, but the car looks covered in some of the videos, and they look quite good after a rinse.
