Wellsy, you got any pics? How is the height compared to the Sportlines?
Sportlines seem the popular choice and height looks good, eibach pro-kit lists it works well with OEM shocks - although I can only assume a lot of people are using the sportline's with OEM shock.
What would be good is side shots of the various setuo and approx drop from each kit ...
I'm looking to order some, been swayed towards the sportlines from the popularity and have seen they look good.
I'll take some tomorrow and put them up for you side on.
I don't think the drop is quite as much as the Sportlines although the main reason I didn't choose the Sportlines is a) recommendation from Damien@DPM, and also to keep a bit more life in the shocks.
Some pics of mine on H&R springs and standard shocks....
H&R are more a back up front down "stance" (hate that word as it stinks of sceneness) than Eibach Sportlines.
Having seen both myself, I prefer Eibach Sportlines.
If I do springs it will be H&R. I think the stance is more suited to the Leon's standard look of back up front down "stance".
Some cars I've seen on the sportlines look just that bit too low at the back for me.
Measured from the bottom of the wheel rim through the centre of the wheel. to the wheel arch and its 590mm front and 595mm rear....so slightly lower at the front but looking at the car its sits level.
Perfect stance. What's the OZ's wheel size - 8J18"et?
Wheels are OZ Superturismo GT's 18x8" ET50.
