Hi,
Ok, I've read so many posts regarding these MFD3 in our Leons & need to clarify some things.
I've decided to go for a VW version as I want the full postcode search. Anyone with a VW version, could you tell me if you have the clock shift issue & the part number of your Can bus gateway..... found using a vag-com.
I need to establish what can bus gateways causes the issue & which ones are ok!
I have a 2007 cupra & believe I'll get the clock shift, so I want to get a newer gateway but I want to confirm with a member the part number that will def work (I have BT & the full MFD).
Or do you get the clock shift with the VW versions, no matter how new your Leon is?
