Timing pull on only one cyclinder
rsmith
Robbie
Apr 28, 2004
2,797
Tipperary, Ireland
Hey Peeps,
Looking for suggestions to my problem that is doing my flippin head in.Over all the car is running great, everything is as it should be but i cannot go any further with tunning untill i get this problem sorted.
I get timing pull(CF's) consistently on cylinder 2, all other cylinders will log 0 CF's where as cylinder 2 will consistently read 5-6 CF's starting at about 3500rpm.
So far i have swapped coils, new plugs(colder again), tried different gaps, 0.028 and then 0.024 and swapped injectors over and its still them same.
Any suggestions, i am not running crazy timing and i am basically stuck.
All and any comments welcome.
Thanks for looking.
Murdered LCR
Wide mouthed mofo
Sep 9, 2006
6,646
8
Murder Inc.
Compression tests are easy take the spark plug out starting from cylinder one screw the compression test in turn the car over for a few seconds until you get a reading on the gauge any where over 10 bar is fine any thing less then your loosing compression
DaNnY_LaD
Big Turbo Leon Cupra R
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
A compression test would tell you that something is wrong in that cylinder is the readings are .5-1bar of each other then there fine...
Takes 20mins todo and you can rule out the mechanic of the cylinder...
rsmith
Robbie
Apr 28, 2004
2,797
Tipperary, Ireland
Compression test results are in, they appear to be in the 10% + - range.
Cylinder 1 = 11.2 bar / 162psi
Cylinder 2 = 10.9 bar / 158 psi
Cylinder 3 = 11.6 bar / 168 psi
Cylinder 4 = 11.8 bar / 171 psi
Cylinder 2 is defo down but not massively out of spec.
Now i am utterly confused:confused:
rsmith
Robbie
Apr 28, 2004
2,797
Tipperary, Ireland
Only just in the 10%, maybe where your problem lies?
True, the highest figure being 11.8 and the lowest 10.9, thats a 0.9 bar difference where the 10% threshold is 1.18bar.
What would cause the pressure to be lower in this cyclinder?
Stick a teaspoon of oil down cyl 2 and test again..make sure its new oil
What would that do? no being smart just trying to learn.
Also is it normal to hear popping when doing the test?
Thanks lads
LEE69
Stage 2 Revo'd
Dec 10, 2004
21,262
74
C\UK\Devon\Torquay
Sorry if the seal of the rings is poor it will be a lower compression.
If the oil makes no difference, it might be the valves leaking.
Popping might be just the other 3 cylinders because they have no plugs in them?
rsmith
Robbie
Apr 28, 2004
2,797
Tipperary, Ireland
Yeah, some guides are saying 10% others 20%, but i would trust the Bentleys manual for sure.
I wonder would carbon build up be the problem, i might run some injector cleaner through the system and see if it improves.
Edit, i run water and methanol & octance booster sometimes, surely my engine should be squeeky clean.
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
if you put oil in too the cylinder and the compression raise its todo with the rings...If it stays the same points toward the valves/Seats....
Me Personally i think 11 bar is rather low...Mine was 13 bar on 1,2,3 but 4 was 11bar which was the one that i had sysmtoms with...
rsmith
Robbie
Apr 28, 2004
2,797
Tipperary, Ireland
Thanks for the tip, reading around some of the peeps are getting different reading with different compression testers, but whats more important is the consistency between the readings, i.e if you have a tester that reads low, it will read low for all the cylinders, same goes for high readings.
But then again this is just from reading around, i have an extensive lack of knowledge in this area.
I would love to know what a new LCR reads.
It's worth checking that the knock sensor for cyl 2 is properly fixed.
;) I must check this too, i have had the connection off for knock sensor 1 several times and its all caked in crap, i must check the voltages in vagcom.
I could also swap knock sensor around as a test.
Edit, further internet research and people are saying cylinder 2 is considered the loudest on the 1.8t because of the block design, if i can confirm this, i might get it desensitised if you know what i mean.
Logging the voltages on the knock sensors at idle suggests this too, all cylinders sit at or below .5 volts, cylinder 2 is always .9 or 1 volt,, hmm interesting.
