Got any photos? You won't need to remove the front bumper, the grill is clipped in.
(it can be removed by a trim tool or a screwdriver even, careful not to mark the paintwork though if your using the screwdriver...large flathead should do the trick).
You do not say if it is the early or face lift Leon, they ARE different has are the bulbs types!! [Had mine hit with only 1k on the clock] when buying off of ebay make sure you getting the right replacement, re my earlier comments !!
You will find there is 1 screw towards the outside corner of the foglight grill. Remove this screw. Then just carefully pull the Grill off - its just clipped into the bumper at the edges, so a good careful tug at that point and it will pull off.
