You need a decent boost control system now. Ditch the N75.
Any timing able to be added with the SEM?
Coming along nicely now.
Coming along nicely now.![]()
Blimey Tuffty, you still on stock rods!I did consider this housing purely based on the potential for it to be a straight swap with mine and just doing the work needed to plumb in the Tial...
However... After working on a couple of cars using this type of housing (including my own) I am not convinced they flow enough to warrant using an external gate...
Bill is mapping an S3 at the moment that has a turbo with my old spec and tbh its going surprisingly well... although it does suffer from horrendous boost creep after 6k... I guess the tial version you have there would go some way to fix that but then so would porting the internal wastegate...
After all the cars I have worked on including my own in the past I can't see the point in using a housing like this one unless you really have too...
My rods are on order now so hopefully be working on mine next month so will see what difference this T25 plus housing will make...
<tuffty/>
Ha Ha, i see, i was thinking to myself you must have balls of steel.LOL... no mate... I have had IE's in since day one ;P
I am going rifle drilled this time around and haven't got time to wait around getting mine done so will fit some Brutes and sell off the IE's...
<tuffty/>
Cool, do you see the small end rattle often or is it limited to a few unfortunate cases.pressure lube to small ends so not going to develop small end rattle like can sometimes occur on non rifle drilled rods
Those pins look familiar, and the fact i don't think you can even buy them separately led me to fork out for some new pistons when i done my rods originally.
Hope the build goes better than todays work.
Hi brilliant write up you have done, what sort of rattle was it you were getting? As I have a annoying rattle changed everything different rods je pistons but sounds like little end rattle, fine when you rev it but rattle on coast down.
awesome car!![]()
