dawson86
236
bury st edmunds
had a little go at removeing the big plastic trim from inside the boot last nite but didn't want to pull to hard, anyone got any tips on getting it out? i removed the 2 screws but couldn't see any others? i am trying to get at the boot release meachanism etc
cheers in advance
its a complete *****. more often than not the trim brakes before the clips give way, then rattles like a sod
I took mine off last weekend to fix my rear washer jet that had been leaking
into the rear arch!!
The boot trim is a complete W.....er to get off and does need some force.,some of the metal clips
Were still in the body of the car and had to pull them out with pliers.
Just make sure you have all the metal clips attached to the trim so it clips back in properly...
Have fun.
Does the main boot panel need to come off to get the pillar trims removed??
