Lol nice multiple quote reply. Can't remember differences in turbo think its on Wikipedia lol but there is no need to change the air induction on a tdi as it has too much air intake already with the standard box
It made me feel dizzy
Panel Filter perhaps but going by info/feedback on here the standard filter was just as good. I can only recall one member who fitted an induction kit to an FR TDi.
http://www.seatcupra.net/forums/showthread.php?t=341546
I have the pd160 Cupra tdi it was standerd with just a jr cone filter fitted a d when u let off ur throttle on that at 2 k revs that makes a dump valve type sound and defo does not have a dv fitted. The tdi engines require a constant pressure behind the turbo if u dump the excess boost pressure in the system ur turbo is going to have to start building up all pressure again there for u would lose power completely not a good idea on a tdi engine unless ur running extreme power ie 300 bhp plus
on a side note, i've just remembered something else the garage told him (him being my mate Dale)
they had a picture of a leon on the wall inside the garage that had its windows tinted (that they'd done) as a sort of promo - the guy who was looking Dales car said "thats a diesel we remapped the other week" and Dale said it had a full K1 kit on it. did the diesel ibiza ever come K1 kitted? or is this further proof that the garage just had no clue
EDIT: sorry for all the questions, i dont know much about diesels, or leons
cheers mate, i'll give that a read in a sec
so anyone who is running a DV on a diesel is either pretending to make themselves sound better, or has some serious power? - probably a nice idea idea actually
this one i saw definitely had a DV though, you could hear it from the other end of the car park, it was loud enough to interupt conversations with people standing a couple of meters away because you couldn't hear them over the TSSSSSSSSSSSSS
Yes any body running a tdi engine with a dv is trying to make them slefs look and sound good but not having a clue how the engine works or they are running some serious power under the Bonnet but even still then I would not fit one.
Also U said about air intake in my opioin I would change the standerd air filter to a cone filter to produce more air intake
Not a dv no. but I would change ur standerd filter to a cone filter the air flow is a lot higher Flowing than ur standerd filter. I would also serjest to get a jr cone filter or green stuff over the others look at my thread under this and u will see mine
Its not coming to an abrupt stop, when you let off the accelerator you’re closing the throttle body and reducing the air flow massive amounts. The blow off then opens and is dropping back pressure to stop the air forcing itself back out past the turbo in the opposite direction.
With the turbo being an impeller that will cause the turbo to slow down rapidly, and if there is enough pressure it’ll cause the turbo to stop and spin the other way. So you drop the back pressure straight away, allowing the turbo to freely spool, then when you’re back on the power the turbo can jump back into action and continue to draw air in – so with a performance blow off, you drop pressure quicker and more efficiently, meaning your throttle response improves since you’re turbo is more active, and you probably get a slight acceleration increase since you’re not having to waste time spooling the turbo back up, reducing the ol’ turbo lag
That’s the way I understand it anyway.
A cone filter is a bad idea on the tdi and a total waste of time, it has no impact on the car at all. The standard air filter is good for around 300bhp anyway.
http://www.youtube.com/watch?v=mMmIqOXxjQU
i got that now brotha
but what i'm suggesting, is me and you trading cars
Blow off valve opens when the throttle body closes. And diesels dont have throttle body, right? So it's impossible for blow off to work on a diesel unless it's operated electronicaly which is a bit pointless at the same time.
Company talking rubbish imo.
Sent from my GT-I9000 using Tapatalk 2
I disagree with the tdi engine being a high pressure induction system
