Stunts
Hi all, I have an issue with water ingress into both front and rear passenger footwells on our Altea XL 2.0tdi DSG and I can't tekk where it's coming from. The pollen filter is below the dash on this model and I popped it out to check - it isn't wet so I'm not convinced the water is coming from there.....
Could it be the common Toledo/Fabia problem of water ingress from the doors? How do I find this out - is there some common sign? How do I get the door cards off anyway? The armrest covers don't seem to want to budge.
Whilst looking under the bonnet I noted that there was some detritus under the front scuttle, so deciding to try to sort it I attempted to remove the wipers. For some odd reason the nut helpfully sheard the post on which the wiper sits. Very P'd off!!!
Any advice on the water would be great. Cheers
Simon
Simon
! If you lift the carpet you will see that the floor isnt flat, all the water gathers in the low areas which will be why its only wet in one place. Alternativley you could have lost one of the rubber bungs that go in the floor, I would say this is pretty unlikely though it's far more likely to be door seals.
