The front/back short shifter is a great mod. Wish I'd done mine way sooner. Had it on about 6 months.
Shifts are quicker and more precise. Can't wait to get my shift bushes on now.
I have a horrible habit of missing 3rd. So hoping to find some help in eliminating that. Mounts are next on the list. Failing that I need to learn how to drive better!
Well, I've jist proved myself incompetent as I have had to give up attempting to change my front to rear shifter. I just couldn't for the life of me get the 13mm nut off that secures the shifter itself! Tried everything I could think of but wouldn't budge, bit gutted now as I've had to put everything back together and don't get to play with something new!:(
Scotty, this wont do anything for the throttle responce as its not got anything to do with this. This is all about gear changes and length of the stick between gears.
I found that other than making things a lot shorter they also took a lot of the slack out of the stick. As in stick it in gear and give it a shake side to side. My bet is there is some there, after fitting mine it has almost all gone.
Fish
Fish
thanks for reply fish :)
Now with 42 draft bushes fitted :)
In my opinion the best combination is forge / modified oem front back linkage, DD42 bushes, standard oem side-side linkage
I have almost the opposite set up and can confirm its crap!
