Adding Extra Gauges and Installing
TomTomTom
Mk3 Ibiza Cupra 230bhp :D
Nov 5, 2011
205
East sussex
Hi I recently bought a Mk3 Ibiza Cupra and it has a single pod piller with a boost gauge, however it is quite highly tuned and would like to fit oil pressure and temperature gauges how to i go about doing this? and where can i get the 3 pod pillar, gauges and parts?
thanks
cuprawill
Turbo lag is foreplay
Nov 20, 2009
703
They don't do a 3 you can buy a Cupra r gauge holder that goes In the centre console as it holds 2 gauges about £10 from the dealer
Deleted member 29494
I also think you should go for the Cupra R double gauge holder. I have a dual gauge Pillar Pod available though if you want that
TomTomTom
Nov 5, 2011
205
East sussex
Thanks guys but i have seen videos and pictures of mk3 cupra's with 3 pods, sure theres no where i could get one? Also how do you wire them in? what do you attach them to in the engine?
carlos180
Hi Lee, my thread has been deleted and i cannot contact you, is that for the end piece or the whole exhaust ??
Carl
james.l
GT3071r LCR
Mar 18, 2008
2,765
My House
www.vagforum.co.uk
Oil temp is measured from the oil filter housing, there is a blanking plate that is removed just above the OEM oil cooler.
Oil pressure should be monitored by the ECU as standard and will throw a light up on the dash should the pressure fall below the threshold.
Nov 2, 2004
9,334
South Wales
Not great advice.
Oil light is too late.
Take the pressure from the oil filter and temp from the sump.
I run boost, AFR, oil temp and oil pressure gauges, greddy EBC and a scangauge 2. 2 in a nomad gauge pod and 2 in a cupra r pod.
