anti submarine design
whats that then ? safety thing ?
When you have a crash the seats that don't have anti submarine design will have their seat base deform as your bottom tries to slide forward and the body tends to slide under the lap part of the belt instead of being retained by it. I think another aspect of it is that your cucksic/spine can be injured if it happens to impact with seat frame.
think the wires have been labeled wrong, the earth is the permanent live to fuse, the live is the earth, and there only 1 wire for the lighting and the other is to switched liveok fitted the Konig seats and installed the loom and switches, switches arent illuminating red though, ive checked from the power source (grey\blue wire) and theres 12v, need to check the cable from the switch end and see if its getting 12v but dont know which are the illumination wires
in this guide it says connect to live and switched, but ive only got one live cable not 2 ?
http://uk-mkivs.net/forums/t/254416.aspx
Get some pics up of them fitted please
Cheers, tried it out this morning on the way to work. Was 2.5 degrees outside, after running the seats on number 5 for 10 minutes I was too hotNice thing to have on a cold winter morning, Looks pretty good as well.
Looking good mate. Seats go with the car spot on.
Hot bum, makes you feel like you've either wet yourself or you're going to.![]()
[QUOTECheers, thanks for the LCR front bumper and the LCR alloy![]()
