Hi guys just quickly when you say that you used self tappers to attach your splitter do you use all the same size tappers or are some bigger/smaller than others if so what size tappers did you use..? Thanks
It doesnt really matter mate, i just got a few from the shed of whatever I had, some where 10mm long, others 20... as long as they're not daft like 50mm or something then its fine. Use the washers that you get with the "fitting kit"
Hi Benjic thanks for the reply I used all the same length in the end and also used the washers from the kit its an absolute doddle to put on with self tappers must say this splitter looks really great I'm well pleased with it. :)
