Nick2008
Onvi tdi-cupra r wannabe!
Aug 22, 2008
283
gloucestershire
Hi all, noticed today that my leon tdi 150 seemed very low on power and torque. I added a k and n induction kit a couple of weeks ago and the car hasn't seemed the same since, I use to be able to pull away in 6th at 40 mph no problem because there was so much torque but now my car just judders and I have to change to 3rd, also there seems to be a tapping noise coming from under the bonnet when I'm going along, am a bit puzzled and worried tbh, all help much appreciated
Missfire perhaps? Read a few ago that the oil from K&N's etc causes the maf to go but have had it diagnosed to check if anything has flagged up?
Hi, the engine management light is on, but that's been on since the start of my ownership, do you no how much it costs to get it checked out? Many thanks
I see your in Glouster, give Bill @ Badger5 a call he's a sound chap, he should sort it ;)
Did you oil the k+n?
If so my guess is your MAF sensor is screwed!
Also why on earth are you pulling 6th gear at 40mph? Do you like replacing dual mass flywheels and clutches?
The problem is your loading the dual mass flywheel and clutch up with torque at low rpm. The flywheels aint the best (i should know) i always downshift and drive more petrol turbo-esque
